Popups lead to crash if operator has 'UNDO' options not set and properties are manipulated
Windows 7, 64bit
Broken: 2.70.4 (1e39046)
Operators which invoke popups and have no 'UNDO' in bl_options crash Blender when edits are made to the properties shown in the popup.
A runtime error is raised if no options are set at all during an invocation, so should a missing 'UNDO' throw an error if invoke_*popup() functions are called in invoke().
Test script:
import bpy
def main(context):
    for ob in context.scene.objects:
        print(ob)
class SimpleOperator(bpy.types.Operator):
    """Tooltip"""
    bl_idname = "object.simple_operator"
    bl_label = "Simple Object Operator"
    bl_options = {'REGISTER'} # no 'UNDO' !
    my_string = bpy.props.StringProperty("My String")
    @classmethod
    def poll(cls, context):
        return context.active_object is not None
    def invoke(self, context, event):
        return context.window_manager.invoke_props_popup(self, event)
    def execute(self, context):
        main(context)
        return {'FINISHED'}
def register():
    bpy.utils.register_class(SimpleOperator)
def unregister():
    bpy.utils.unregister_class(SimpleOperator)
if __name__ == "__main__":
    register()
    # test call
    bpy.ops.object.simple_operator('INVOKE_DEFAULT')
codemanx created this task.Apr 30 2014, 8:30 PM
codemanx raised the priority of this task from to 90.
codemanx updated the task description. (Show Details)
codemanx edited a custom field.
codemanx added a subscriber: codemanx.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Apr 30 2014, 9:29 PM
Closed by commit rB4b7595633006.
