When Boolean operator on an object interacts with children of the same object the update is delayed whenever location of the parent is changed. as well when the file is loaded the update is missing completely. it's probably the wrong update order. it needs to update children first then the modifier stack
Broken: (example: 2.69.7 4b206af, see splash screen)
