Windows 7 and Linux Ubuntu
Broken: 2.70 19e627c
When adding a effect strip between two strips in VSE, the strip is by default placed between the two strips on the same channel. But this does not work in the preview and neither in the render. It works only if the effect strip is placed on an other channel.
Not sure, if this is a bug or if I miss something obvious...
Thank you very much,
Ralph
