CUDA running out of memory on scene with 2.71-testbuild1 that renders OK on 2.70a
Xubuntu-64 12.04;
Intel i7; 12GB DDR3; NVidia GTX570
Broken: (example: 2.69.7 4b206af, see splash screen)
2.71-testbuild1
2.70a
Testing a scene with a sIBL environment loaded. Renders fine with CPU but GPU fails for lack of memory (GTX570 has 1.2GB memory, textures no more than 20MB from sIBL).
Example scene tested sIBL "Basketball Court":
BasketballCourt_3k.hdr ...... 16.5 MB
BasketballCourt_8k.jpg ....... 19.0 MB
BasketballCourt_Env.hdr ..... 157.5 KB
Only object in scene is default cube.
Run the attached .blend with 2.71-testbuild1 with CUDA enabled/disabled and compare with 2.70a render results.
Chris Hanning (submergedfin) changed the task status from Unknown Status to Resolved.Jun 11 2014, 6:26 AM
Chris Hanning (submergedfin) claimed this task.
blender 2.71-testbuild2 renders the test blend file with CUDA enabled so the problem is solved.
