Confusing crown group error.
32-bit Windows XP SP3
2.8 Ghz single core Pentium 4
2 GB RAM
Geforce 6200 256MB
Broken: 2.70, Hash: 19e627c
SCA Tree Generator version 0.2.14
Make a crown group and and move it to a non-visible layer. Try to use the crown group in the Tree Generator add-on toolbar, and it will give a confusing error difficult for end users to understand.
Request using a simple check to see if the crown group is on same layer and telling user "All layers with selected crown group need to be visible" if not.
Thank you for reading.
James Russell (Henrymop) raised the priority of this task from to 90.
James Russell (Henrymop) updated the task description. (Show Details)
James Russell (Henrymop) edited a custom field.
Is this the error you are getting?
pointInsideMesh line 94:
'SummerLeaf' has no mesh data to be used for ray casting
Here it is. Just a FYI rather than a full "bug".
So it's the ray_cast() method and I believe it is caused by object being in edit mode - there's no data for raycasting in that mode.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Jul 2 2014, 2:10 PM
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Unknown Status.Jan 8 2016, 6:56 AM
Archiving. No activity 1.5 years.
