Broken: 2.71 RC2 (a19c1be)
When defining all limits in "Limit Scale" to 1, it is possible to scale to -1 and flip the mesh.
- With startup settings, add a cube. In edit mode, scale the top side to .5
- Add an empty beside the cube. Make sure it is outside the cube.
- Parent the cube to the empty.
- In the empty's constraints menu, add a "Limit Scale" constraint. Activate and set all of its minimum and maximum values to 1.
- Select the empty, and scale it down until you see a change, or just type "-1" to do it automatically.
I haven't tested this with the other constraints. The blend file is here:
