Can't access actually used values of macro operator properties from Python
Windows 7, 64bit
Broken: 2.71 RC2
Logged operators in WindowManager.operators also include Macros, but if their arguments are retrieved, they are all at their default values.
  • Go to Scripting view
  • Shift + D to duplicate linked
  • Paste and Run script:
import bpy
from collections import Iterable
from mathutils import Vector, Matrix
from _bpy import StructMetaPropGroup
def main():
    for op in bpy.context.window_manager.operators:
        cmd = format_logged_op(op)
        print(cmd)
def format_logged_op(op):
    tmp = []
    for k in op.properties.keys():
        p = getattr(op.properties, k)
        if isinstance(type(p), StructMetaPropGroup):
            props = format_macro_props(p, p.bl_rna.properties.keys())
            tmp.append("%s={%s}" % (p.bl_rna.identifier, props))
        else:
            tmp.append(format_key_value(k, p))
    return "bpy.ops.%s(%s)" % (format_idname(op), ", ".join(tmp))
def format_macro_props(prop, keys):
    tmp = []
    for k in keys:
        if k == "rna_type":
            continue
        p = getattr(prop, k)
        tmp.append(format_key_value(k, p, fmt='"%s": %r'))
    return ", ".join(tmp)
def format_key_value(k, p, fmt="%s=%r"):
    if isinstance(p, Vector):
        p = p.to_tuple()
    elif isinstance(p, Matrix):
        p = "(%s)" % ", ".join(repr(vec.to_tuple()) for vec in p)
    elif not isinstance(p, str) and isinstance(p, Iterable):
        p = p[:]
    return fmt % (k, p)
def format_idname(op):
    return ".".join(op.bl_idname.split("_OT_", maxsplit=1)).lower()
main()
It will print
bpy.ops.mesh.duplicate_move(MESH_OT_duplicate={"mode":1}, TRANSFORM_OT_translate
={"value":(0.0, 0.0, 0.0), "constraint_axis":(False, False, False), "constraint_
orientation":'GLOBAL', "mirror":False, "proportional":'DISABLED', "proportional_
edit_falloff":'SMOOTH', "proportional_size":1.0, "snap":False, "snap_target":'CL
OSEST', "snap_point":(0.0, 0.0, 0.0), "snap_align":False, "snap_normal":(0.0, 0.
0, 0.0), "texture_space":False, "remove_on_cancel":False, "release_confirm":Fals
e})
so everything False, 0.0 or whatever is default...
Revisions and Commits
codemanx created this task.Jun 23 2014, 2:22 AM
codemanx raised the priority of this task from to 90.
codemanx updated the task description. (Show Details)
codemanx edited a custom field.
codemanx added a subscriber: codemanx.
I may be wrong, but IIRC macro operators in fact don't have properties of their own (or at least they don't inherit properties from nested operators by default). Including nested operator properties in the macro's dict would be dangerous. How would you handle name conflicts etc.?
If anything, the nested operators' properties should be accessible as a collection inside the macro (something like window_manager.operators[-1].macro[0].properties). This is actually how properties are stored for macros and how the redo panel accesses and displays them. I don't know why these are not exposed already in the RNA, maybe @Campbell Barton (campbellbarton) can say?
About dynamic enums: Yes, this is annoying ... In principle dynamic enums can depend on context even, but in most cases they're just used to select a fixed list based on some other property. There are classmethods in UILayout which could be used for resolving enum names, descriptions and icons, but not for mapping index <-> identifier. Something like this would be very handy (if it doesn't exist somewhere else already?).
Use attributes instead of dictionary keys.
bpy.context.window_manager.operators[-1].properties['constraint_orientation']
bpy.context.window_manager.operators[-1].properties.constraint_orientation
The dict keys() can be used to getattr()
Lukas Tönne (lukastoenne) changed the task status from Unknown Status to Archived.Jun 23 2014, 2:18 PM
Lukas Tönne (lukastoenne) claimed this task.
Ah yes, @Morshidul Chowdhury (iPLEOMAX) is right. The nested operator properties can be accessed as attributes. To get all their properties you could use the RNA type info:
props = bpy.context.window_manager.operators[-1].properties.OBJECT_OT_duplicate.bl_rna.properties.keys()
Closing this report.
codemanx renamed this task from WindowManager.operators does not resolve macro properties to Can't access actually used values of macro operator properties from Python.Jun 24 2014, 9:31 PM
codemanx changed the task status from Archived to Unknown Status.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Jul 2 2014, 2:12 PM
Yeah… I had to fight that issue in C as well, to allow the log/info window to show valid parameters in this case too, some time ago… Sounds more like a TODO to me, tbh.
IDK what the problem here is actually ...
Campbell Barton (campbellbarton) triaged this task as 50 priority.Sep 3 2014, 2:21 PM
Confirmed. but changing Py/RNA API right before release is too risky (unless its obvious fix for mistake)
Expose via operator.macros, a list of macros whos properties you can access.
This is a bit awkward but its how the data is stored internally.
Better silly than sorry ;-)
