Can't Erase Grease Pencil (Hold D+RMB) in VSE
Linux 64
Broken: 2.71 8d6f546
Worked: 2.70a
Cannot erase grease pencil by holding D + RMB
  1. Open blender, change to VSE layout
  2. insert movie sequence
  3. Press D + LMB and draw grease pencil in sequencer preview
  4. Try erase by holding D + RMB, nothing happened
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Jun 30 2014, 5:11 PM
First of all, pleas do not assign tasks yourself, unless you are sure about what you’re doing, this is typically dev’s job.
That said, I can’t reproduce this here, D+RMB works fine for me. Please try to start Blender with --factory-settings option, to be sure you did not 'shadowed' this shortcut with a custom one. If it still does not work, please attach a .blend file reproducing the issue.
It is confirmed, one of the add-on which causing this is VSE Transform Tool. I've disable this add-on and everything works now. Thanks.
Aditia A. Pratama (aditiapratama) changed the task status from Unknown Status to Archived.Jul 1 2014, 12:29 AM
