'At Last' and 'At First' options disappear from merge menu
Windows 7 64 Bit
AMD Radeon HD 6950
Broken: (example: Blender 2.70 and 2.71
Worked: (optional) Blender 2.69 and earlier
In some instances 'At Last' and 'At First' disappears from the merge menu and the only way to get them back seems to be to modify the selection.
This is one way to reproduce the problem, I have however encountered it in other situations too:
  1. Add a default cube.
  2. Select two vertices (with Shift+RMB).
  3. Remove doubles.
  4. Try to merge the vertices at the first or last position and you'll see that those options are gone.
Robin Karlsson (nosslak) raised the priority of this task from to 90.
Robin Karlsson (nosslak) updated the task description. (Show Details)
Robin Karlsson (nosslak) edited a custom field.
This happens because 'remove doubles' erases selection history, hence there is no more 'first' or 'last' selected vertex…
Would say this is not a bug, but will let Campbell decide here.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Jul 1 2014, 12:37 PM
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Jul 2 2014, 8:58 PM
We could make some tools keep selection history, but this isnt a bug.
