Make Local button on the scene selection drop-down does not work
Linux bubastis 3.10.25-gentoo #10 SMP Thu Jan 30 22:17:35 UTC 2014 x86_64 Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz GenuineIntel GNU/Linux
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1) (prog-if 00 [VGA controller])
Broken: git 0ea73023496d6af81b750a95395c3190f1c95039
Broken: 2.71 RC2
The "make local" button on the scene selection drop-down at the top of the UI does not actually convert the linked scene to a local scene.
Use the File / Link menu option to link a Scene from an external file.
Use the scene drop-down to select that scene.
Click the "make local" button.
Become disappointed.
workaround
Create a new scene that links all the objects from the linked scene using the + / Link Objects menu option. After that is done you can unlink the linked scene.
Robert Forsman (mutantbob) raised the priority of this task from to 90.
Robert Forsman (mutantbob) updated the task description. (Show Details)
Robert Forsman (mutantbob) edited a custom field.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to 50.
Will have a look later.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Aug 12 2014, 7:49 PM
Yeah, there are quite a few of unsupported datablocks in there. That's annoying, but technically it's not a bug, just a thing to be improved.
Thanks for the report, we'll get into this one once the number of actual bugs is lower.
