minor issue with tree generator (Sapling add-on)
Operating system and graphics Card
Windows 7 Pro 64 bit, Intel on board grapics
Broken: 2.71
When creating a tree, the number of leaves doesn't change if branch splitting level is 2. With level 3 it works.
Add curve -> Tree -> check "bevel". All of the other settings can remain as they are. Then goto section "Leaves" and check "show leaves". The number of leaves attached to the tree doesn't change if you change the value in the belonging input field. If you go to section "branch splitting" and increase the branch level to 3 then you can set the number of the leaves as you want and they are shown / attached correctly.
(Maybe this is actually a feature but to me it appears like a bug.)
Thanks.
Ernst Hammann (JASMS) raised the priority of this task from to 90.
Ernst Hammann (JASMS) updated the task description. (Show Details)
Ernst Hammann (JASMS) edited a custom field.
I found what I believe to be the problem. in the add_curve_sapling/utils.py:
if n == 1:
    # If this is the first level of branching then upward attraction has no effect and a special formula is used to find branch length and the number of child stems
    vertAtt = 0.0
    lMax = length[1] + uniform(-lengthV[1], lengthV[1])
    branchL = p.lengthPar * lMax * shapeRatio(shape,
                                              (p.lengthPar - p.offset) / (p.lengthPar - baseSize * scaleVal))
    childStems = branches[2] * (0.2 + 0.8 * (branchL / p.lengthPar) / lMax)
elif storeN <= levels - 2:
    branchL = (length[n] + uniform(-lengthV[n], lengthV[n])) * (p.lengthPar - 0.6 * p.offset)
    childStems = branches[min(3, n + 1)] * (1.0 - 0.5 * p.offset / p.lengthPar)
# If this is the last level before leaves then we need to generate the child points differently
else:
    if leaves < 0:
        childStems = False
    else:
        childStems = leaves * shapeRatio(leafDist, p.offset / p.lengthPar)
When levels==2, then the n==1 clause shadows the leaf clause at the end. If we move the leaf clause to the top it works like you want:
if (storeN>= levels-1):
    if leaves < 0:
        childStems = False
    else:
elif n == 1:
    vertAtt = 0.0
