Drag Vertex is hard in Edit Mode when turn on background image
I use a sample picture as background image for modeling a head.
And in Edit Mode, drag move mesh's vertices is very difficult. Program is dull respond mouse move. But if turn off background image, dragging vertex is smooth.
OS: win2000
3D Card: ATI MOBILITY RADEON 9700
Blender version: 2.41 build on 01/23/2006
Logged In: YES
user_id=4679
I have got the same 3D card as you. My OS is Windows XP Pro and I am using the same version of Blender as you are.
I think that the issue is ATI specific. I have noticed similar behaviour as you in the render window. Hit z to zoom and you will notice it.
The issue appears also in the UV/Image Editor if you load an image and pan it around.
I have figured a workaround for the background image issue: You can uv map an image to a plane.
There are some minor issues in this approach though but at least it works.
Logged In: YES
user_id=103
Yes, it really depends on the quality of your 3d card what gets accellarated or not. Drawing images using 'pixmap' can be relatavily slow on some systems. On other systems it's blazing fast though (ATI 9600 here, and it goes excellent).
Logged In: YES
user_id=4753
Maybe using transformed and lit vertices to draw background image is a good choice.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:16 AM
