Blender version: 2.71 (but 'bug' has 'always' been there)
Hi there!
When in Sculpt Mode with Constant Detail Selected, Shift-D does nothing when it should set the Detail Size I presume?
Also manually selecting Detail Size with the slider, it is very difficult to do so. Any value above let's say 15% is never usable (way too rough/large tris), so selecting has to be between 0-15% which is very difficult to do (with a tablet).
maybe the scaling/range should be looked at.
(I've tested the range with suzanne as a base model, because when sculpting in let's say 20 times real life scale, the slider starts to behave normally, but other unrelated problems start to emerge when doing that..)
I hope you understand what the problem is and thanks for looking into it!
Thanks, keep up the amazing work you do!
Roel
