Transparent background and volume emission material
Win7 x64, 7970 Radeon
Broken: 2.70a # f93bc76
http://i.imgur.com/4fGn9uv.png
Rendered result to the left, preview and expected result to the left.
Independently confirmed by two users in #blender.
Press Ctrl-Z in the 3D view to the right and F12.
(Drag-and drop doesn't work with IceWeasel in this web app, Pale Moon won't do this web-app's CSRF tokens, and Chromium has withered away.) Here is a link to pasteall.org http://www.pasteall.org/blend/31066
Do do it manually, assign Material > Volume > Emission to an object and set Render > Film > Transparent.
Tomas (nanicoar) raised the priority of this task from to 90.
Tomas (nanicoar) updated the task description. (Show Details)
Tomas (nanicoar) edited a custom field.
Here's a simple demo file that was used to confirm this behavior.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Aug 20 2014, 10:55 AM
Sergey Sharybin (sergey) claimed this task.
Blender converts images to the straight alpha before displaying them on the screen (because of the way how ogl is set up), which makes it look like there's no color in the transparent area.
Now, in order to see the values you need to composite the render result on something. Easiest way is to use RGB display mode in the image editor which would composite the render onto the black background.
For now it's not considered a bug, it's just how alpha works in blender. Thanks for the report anyway.
