Windows 7 64, HD 5770
Broken: 9337574 (2.71 release) & 4b4ae83
If an Emtpys Display Type was set to a loaded Image and changed after (back to "Plain Axes" for example), the Empty is still handled as a user for the image.
I am not sure if this is intended - but this makes it hard to locate and clean up the unnecessary image if its hidden in an unused option.
Unfortunately I dont know how to delete it. Right click "Reset to default value" dont work, same in the datablocks.
Please note: Deleting the Empty helps in this case, but is not always desirable when the Empty is used as a Bone-Shape or in a modifier.
- Create an Empty
- Set Emptys Display Type to "Image"
- Load any Image
- Change Emptys Display Type to a different option (Plain Axes for example)
- Problem: Image stays in the file, although it is not used.
