Error message on trying to import COLLADA triangle strips is wrong
MacOSX 10.9.4 on PowerBook with NVIDIA GeForce GT 750M 2048 MB
Broken: NVIDIA GeForce GT 750M 2048 MB
I am writing Collada files with <tristrips> (as defined in http://www.khronos.org/files/collada_spec_1_5.pdf) and importing these in Blender. The console shows an error message "Primitive type TRIANGLE_FANS is not supported." but should show "Primitive type TRIANGLE_STRIPS is not supported."
I think steps to reproduce are not necessary. The source code shows there is an error in the switch:
static const char *bc_primTypeToStr(COLLADAFW::MeshPrimitive::PrimitiveType type)
	switch (type) {
		case COLLADAFW::MeshPrimitive::LINES:
			return "LINES";
		case COLLADAFW::MeshPrimitive::LINE_STRIPS:
			return "LINESTRIPS";
		case COLLADAFW::MeshPrimitive::POLYGONS:
			return "POLYGONS";
		case COLLADAFW::MeshPrimitive::POLYLIST:
			return "POLYLIST";
		case COLLADAFW::MeshPrimitive::TRIANGLES:
			return "TRIANGLES";
		case COLLADAFW::MeshPrimitive::TRIANGLE_FANS:
			return "TRIANGLE_FANS";
		case COLLADAFW::MeshPrimitive::TRIANGLE_STRIPS:
		case COLLADAFW::MeshPrimitive::POINTS:
			return "POINTS";
		case COLLADAFW::MeshPrimitive::UNDEFINED_PRIMITIVE_TYPE:
			return "UNDEFINED_PRIMITIVE_TYPE";
	return "UNKNOWN";
