Windows 7 64-bit, GTX 580
Broken: BuildBot 2.71 revision ea07d93 (August 18th, 2014), at least all the way back to the beginning of July.
Run a little Python script like this:
import bpy bpy.context.scene.frame_set(-1)
What frame does that set the scene to? You'd think it would be frame -1, but instead it's frame -2! If you enter any negative number n into frame_set(), it will set the scene to frame n-1. If you enter any non-negative number nn into frame_set, it will set the scene to frame nn.
I've been able to set the frame to -1 only by doing this:
bpy.context.scene.frame_set(-1,subframe=0.5)
But I don't think that's how it's supposed to work.
This (
import bpy #bpy.context.scene.frame_set(2) #This gives frame 2 #bpy.context.scene.frame_set(1) #This gives frame 1 #bpy.context.scene.frame_set(0) #This gives frame 0 #bpy.context.scene.frame_set(-1) #This gives frame -2 #bpy.context.scene.frame_set(-2) #This gives frame -3 #bpy.context.scene.frame_set(-1,subframe=0.5) #This gives frame -1
Uncomment any one of the lines and verify that the frame that the scene was set to matches the end-of-line comment's predictions.
