Cast modifier - Edit Cache problems
Windows 7 64, HD 5770
Broken: 9337574 (2.71 release) & 1987548
Instanced objects (mesh or curve for example) are going crazy (spin around)
if minimum 2 in the same instance have a Cast modifier, same target object, Use Transform and Edit Cache activated.
  • Add an Empty.
  • Add a Cube, give it a Cast modifier.
  • In Cast modifier:
    • Set control object to Empty.
    • Activate Use Transform option.
    • Activate Apply modifier to editing cache during edit mode in the header.
  • Make a linked duplicate (ALT+D) of Cube.
  • You can place all objects how you like.
You have now 2 linked Cubes, using the same target for Cast.
IMPORTANT: Move Empty -> Weird deformation on both cubes.
NOTE: This behaviour ends if one of the above mentioned requirements is missing.
Karja Krähwald (karja) raised the priority of this task from to 90.
Karja Krähwald (karja) updated the task description. (Show Details)
Karja Krähwald (karja) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
