blender 2.71 open only if compatible with windows7
windows7 64
ASUS ATI Radeon HD6870
Broken: (2.71 and all official and not official releases(2.71.3;2.71.6))
Worked: (2.70 and all earlier)
blender all releases later 2.71.
to open we bust switch on compatible with windows7
blender.exe\click RMB\properties\ switch compatible and select wondows7
in all earlier versions it is not important,but if we switch on this - working faster.
i'm not sure is this bug, but i write about this just in case
Alexey (Inwader77) claimed this task.
Alexey (Inwader77) raised the priority of this task from to 90.
Alexey (Inwader77) updated the task description. (Show Details)
Alexey (Inwader77) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
the buildbot was bundling msvcr120.dll that was not the exact one that was used to build blender up until yesterday.
Could you retest today's version.
Also do you have service pack 1 installed ?
"in all earlier versions it is not important,but if we switch on this - working faster." does it not work or does it work better with that switch ??
Alexey (Inwader77) added a comment.EditedAug 31 2014, 3:45 PM
What is toda's version?
and what is servise pack1?
working normal, but:
if we switch on compartible - working faster
if we don't switch - working too, but not so fast
i was download 0b4da96 - working with bug
i have windows 7ultimate - 64 service pack1
I would classify this as an OpenGL driver issue.
Could you maybe explain how you measure that blender is faster ?
And maybe also add the information in Russian if your Russian as I really have trouble knowing what the exact problem is.
Alexey (Inwader77) added a comment.EditedAug 31 2014, 6:54 PM
I was open any version 2.71 and earlier, set compatible with windows7
and i was see:
click blender.exe
blender faster start(open) - it is so visibly
in work:
it is not so visibly, but faster
But main problem - in 2.71(official and not official releases) - if we don't set compatible with windows7
and click blender.exe - blender don't start.
Alexey (Inwader77) added a comment.EditedAug 31 2014, 7:02 PM
and else:
if i download(2.71 and later) any version in arhive, open this arhive, and click blender.exe(only first time) - blender start normal, but second time, and all others, and if unpack arhive - don't start without switching on compatible with windows7
but only c5a2c08 don't open first time in arhive
Does this also happen with opening blender-app.exe?
please retest with build from the buildbot 4776d80a or newer https://builder.blender.org/download/
Alexey (Inwader77) added a comment.EditedSep 5 2014, 5:20 PM
in 4766d80a i was open only first time after download, and second time and all others don't open without compartible with windows7, blender app exe too.
in 4766d80 we can set compartible with windows7 in blender app exe and don't set for blender exe, klick blender exe - blender open normal.
Thomas Dinges (dingto) changed the task status from Unknown Status to Archived.Nov 20 2014, 4:08 AM
I close this as the issue is not reproducible on our systems. This seems specific to your system.
