windows7 64
ASUS ATI Radeon HD6870
Broken: (All,but 35bc266 - special case)
Worked: (none)
in 35bc266:
if we create material, uv map with image
in multitex mode in textured and solid modes if we erase alpha will not see proper color of material
in GLSL textured, rendered,material - working properly
go to other(object, sculpt,edit) modes - we will not see alfa erase
if delete only material(not uv map) - we will not see transparent - error
in all official releases:
we will not see alfa erase in either mode(sculpt,tex paint,edit)
if delete only material(not uv map) - we will see transparent - properly
P.S.
in all previews, icons - working normal.
open this with 35bc266:
try to erase alpha, and change material color - we will not see changing in 3d view
go to other mode(object for example) - we will not see erased alpha
delete material - we will not see transparent - error
open with official release:
try to erase alpha and we will not see in 3d view results
switch between different modes(edit,object,sculpt) - we will not see result
delete material - we will see properly transparent
