Shading problems with Autosmooth & Material Transparency
Windows 7 64, HD 5770
Broken: 9337574 (2.71 release) + f0f398d
Blender Render:
Viewport shading in texture mode has problems with Autosmooth:
  • if minimum 2 materials are assigned on the mesh
  • if they differ in their transparency checkbox setting (enabled or not)
  • if Properties>Object>Display>Transparency is checked.
(All three must be true at the same time)
This seems only visible in Objectmode, Editmode and Render arent affected.
  • Add a Lamp (Point).
  • Add a Cube.
    • Go to Properties>Object Data>Normals>enable Autosmooth.
    • Go to Properties>Object>Display>enable Transparency.
    • Give Cube 2 materials (different color).
      • Assign them both on the mesh.
      • Enable Transparency for only one material.
  • Set Viewport to Blender Render & Textured Mode.
Problem: Wrong shading and shadows in Objectmode.
Note that if you assign only transparent materials, or only non-transparent materials on the mesh, the problems disappear.
Karja Krähwald (karja) raised the priority of this task from to 90.
Karja Krähwald (karja) updated the task description. (Show Details)
Karja Krähwald (karja) edited a custom field.
T41684 is similar or maybe same problem. It could be linked or merged, but I dont know how to do that.
@Karja Krähwald (karja), they might be related, but T41684 is a problem in the gameengine. whereas this is blender-renderer.
