Cycles ID pass (Objekt and Material) Bug.
Closed, ArchivedPublicTO DO
Win 7 64Bit - GTX 650
Blender 2.71
Hash: 9337574
25.06.2014
Since there is on no roadmap, an indication that this bug shall fixed ... Here a reminder!
The ID pass has no grayscale values, that makes it unusable for compositing.
Any Workaround (e.g emission material override) is really a bit frustrating and time consuming.
http://blenderartists.org/forum/showthread.php?342262-Cycles-ID-mask-looks-low-sample
It must be possible (however), to create a clean black and white mask otherwise the Cycles ID passes are useless.
Please Devs, fix this existentially feature!
Screenshot
PSD packed with 7z
Blend
Hans Nolte (ditos) raised the priority of this task from to 90.
Hans Nolte (ditos) updated the task description. (Show Details)
Hans Nolte (ditos) added a project: BF Blender.
Hans Nolte (ditos) edited a custom field.
This bugtracker is *not* for feature requests. Therefore I set this to a ToDo task now.
And as already noted by someone in the Blenderartists thread, the missing AA comes from the fact, that the ID passes are only rendered with 1 sample.
Thomas Dinges (dingto) lowered the priority of this task from 90 to Low.Sep 23 2014, 4:31 PM
Thomas Dinges (dingto) changed the task status from Unknown Status to Archived.Sep 23 2014, 4:36 PM
Actually, this is intended behaviour: http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Passes
"The Z, Object Index and Material Index passes are not antialiased. This is done because such values can't really be blended correctly. "
Thanks Thomas to set this to a ToDo task.
