Well, first time trying to use blender and it doesn't work. When I start blender it says, "Blender has stopped working - Windows is searching for a solution" and then that pop-up changes to, "A problem has caused the program to stop working - Windows will close the program and notify you if a solution is available". In the small black command prompt that pops up it says, "SyntaxError: Invalid syntax". This is pretty annoying and just want it to work. When I first installed the program I accidentally clicked the USA mirror download. When I realised I had done this I clicked the 64Bit download, downloaded and installed it and this is what happens.
Specs;
GPU - Geforce GTS 450 1.5GB
CPU - intel(r) core(tm)2 quad cpu q8300 2.5ghz
Memory - 8GB RAM
OS - 64Bit Windows 7
Hard drive - 2* 290GB
I'm not sure whether or not the problem I'm having is hardware related or not, please help, would love to use this software.
