Windows 7 64-bit
Intel HD Graphics 4000
Broken: 2.69 r60995, 2.70 19e627c, 2.71 9337574, 2.72rc eb464ee
Worked: 2.67 r56533 2.68a r58537
import bge
for i in range(3):
print('LibNew:', i)
bge.logic.LibNew('New', 'Mesh', ['Plane'])
print('LibFree:', i)
bge.logic.LibFree('New')There is a Plane on the inactive layer that is using the default material.
The BGE crashes after calling LibFree twice on objects that have a material attached.
Open crash.blend. Press P to start the BGE. Blender will immediately crash after printing the following to the console:
LibNew: 0 LibFree: 0 LibNew: 1 LibFree: 1
This shows the crash occurs at the second call to LibFree.
Additional Notes
- The calls to LibNew/LibFree do not have to happen on the same frame for the crash to occur.
- Changing the name of the library each loop has no effect
- Changing the mesh/material that LibNew/LibFree is called on each loop has no effect. The only requirement is that the objects have a material
- It does not matter if the object passed to LibNew is on an active or inactive layer.
- The crash happens on both Multitexture and GLSL shading modes.
