Changing Node Editor header color also changes wire color
OS X 10.8.5 ATI Radeon HD 4850 512 MB
Broken: 2.72 95182d1
Customizing the Header color for the Node Editor also brings the node wire color with it. The colors of the two elements are linked.
There is a color option called "Wire" which changes the outer wire color, but the only way to change the inner wire color is to change the header color.
  1. Open the Node Editor and make some nodes.
  2. Open Preferences, Themes tab, and go to the Node Editor section.
  3. Change the color for "Header" and see that the inner part of the node wires change too.
Seth L. (quantumanomaly) raised the priority of this task from to 90.
Seth L. (quantumanomaly) updated the task description. (Show Details)
Seth L. (quantumanomaly) edited a custom field.
Kevin have a patch for this, currently being reviewed by Lukas. Assigning to Lukas so people are not being confused and tries to fix this issue again.
