Blender 2.72 (sub 0) System Information
Blender:
version 2.72 (sub 0), branch b'master', commit date b'2014-10-03' b'13:58', hash b'95182d1', b'Release'
build date: b'2014-10-03', b'16:49:19'
platform: b'Windows:32bit'
binary path: 'D:\\Game making\\Blender\\blender-2.72-windows32\\blender-app.exe'
build cflags: b'-DWITH_FREESTYLE /nologo /J /W3 /Gd /w34062 /wd4018 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /we4013 /we4431 /DOIIO_STATIC_BUILD /openmp -O2 /Ob2 -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DOPJ_STATIC -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -DLITTLE_ENDIAN -DWITH_AUDASPACE -DWITH_AVI -DWITH_OPENNL'
build cxxflags: b'/nologo /J /W3 /Gd /w34062 /wd4018 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /we4013 /we4431 /DOIIO_STATIC_BUILD /openmp /EHsc -O2 /Ob2 -DWIN32 -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_DEPRECATE -DOPJ_STATIC -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -DLITTLE_ENDIAN -DWITH_AUDASPACE -DWITH_AVI -DWITH_OPENNL'
build linkflags: b'/SUBSYSTEM:CONSOLE /MACHINE:IX86 /STACK:2097152 /INCREMENTAL:NO /LARGEADDRESSAWARE /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib'
build system: b'SCons'
Python:
version: 3.4.1 (default, Aug 29 2014, 15:47:12) [MSC v.1800 32 bit (Intel)]
paths:
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\scripts\\addons'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\scripts\\startup'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\scripts\\modules'
'D:\\Game making\\Blender\\blender-2.72-windows32\\python34.zip'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\python\\DLLs'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\python\\lib'
'D:\\Game making\\Blender\\blender-2.72-windows32'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\python'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\python\\lib\\site-packages'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\scripts\\freestyle\\modules'
'D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\scripts\\addons\\modules'
'C:\\Documents and Settings\\acer\\Application Data\\Blender Foundation\\Blender\\2.72\\scripts\\addons\\modules'
Directories:
scripts: ['D:\\Game making\\Blender\\blender-2.72-windows32\\2.72\\scripts']
user scripts: 'C:\\Documents and Settings\\acer\\Application Data\\Blender Foundation\\Blender\\2.72\\scripts'
pref scripts: None
datafiles: 'C:\\Documents and Settings\\acer\\Application Data\\Blender Foundation\\Blender\\2.72\\datafiles\\'
config: 'C:\\Documents and Settings\\acer\\Application Data\\Blender Foundation\\Blender\\2.72\\config\\'
scripts : 'C:\\Documents and Settings\\acer\\Application Data\\Blender Foundation\\Blender\\2.72\\scripts\\'
autosave: 'C:\\Documents and Settings\\acer\\Application Data\\Blender Foundation\\Blender\\2.72\\autosave\\'
tempdir: 'C:\\DOCUME~1\\acer\\LOCALS~1\\Temp\\blender_a02112\\'
FFmpeg:
'avcodec':' ''55, 39, 101'
'avdevice':' ''55, 5, 100'
'avformat':' ''55, 19, 104'
'avutil':' ''52, 48, 101'
'swscale':' '' 2, 5, 101'
Other Libraries:
OpenColorIO: 1, 0, 8
OpenImageIO: 1, 4, 12
OpenShadingLanguage: 1, 5, 10
renderer: 'Intel 945GM'
vendor: 'Intel'
version: '1.4.0 - Build 7.14.10.4926'
extensions:
'GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture' 'GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp' 'GL_ARB_texture_compression GL_ARB_texture_cube_map' 'GL_ARB_texture_env_add GL_ARB_texture_env_combine' 'GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar' 'GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object' 'GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra' 'GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax' 'GL_EXT_blend_subtract GL_EXT_clip_volume_hint' 'GL_EXT_compiled_vertex_array GL_EXT_cull_vertex' 'GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays' 'GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color' 'GL_EXT_separate_specular_color GL_EXT_shadow_funcs' 'GL_EXT_stencil_two_side GL_EXT_stencil_wrap' 'GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add' 'GL_EXT_texture_env_combine GL_EXT_texture_lod_bias' 'GL_EXT_texture_filter_anisotropic GL_EXT_texture3D' 'GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat' 'GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap' 'GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_WIN_swap_hint '
Implementation Dependent OpenGL Limits:
Maximum Fixed Function Texture Units: 8
GLSL:
Maximum Varying Floats: 8
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 16
Maximum Fragment Uniform Components: 16
Maximum Vertex Image Units: 16
Maximum Fragment Image Units: 16
Maximum Pipeline Image Units: 16
Broken: (example: 2.69.7 4b206af, see splash screen)
I created the word "n" in blender.I connected all the points and created a face. When I zoom out using the wheelmouse, some edges of the "n" word tends to go out of place and make the "n" word looks weird as the edges are crooked. However, when i zoom in again the edges are in the correct places again.
zoom in to a single grid(with wheelmouse)
tab in to edit mode
use ctrl+left mouse to draw dots and make any word with curve parts
press F to create a face
tab back into object mode(the problem works in edit mode too)
zoom out(with wheelmouse)
