AVI JPG target: index block missing
Win7/64, GTX 750 Ti
2.72
If the output format is AVI JPG, the resulting file, if opened in VirtualDub, leads to the error message "missing index block".
The GSpot tool says about the same file: "Bad chunk in frame data: Invalid length"
The happens with any created AVI JPG file. The current one is 5 GB, so I can't send it.
Create an AVI JPG file.
Willi (willi) raised the priority of this task from to 90.
Willi (willi) updated the task description. (Show Details)
Willi (willi) edited a custom field.
Willi (willi) added a subscriber: Willi (willi).
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 30.Oct 23 2014, 10:42 AM
We need reproducible steps to redo an error,
marking incomplete.
  1. Open Blender
  2. In a scene of your choice, go to the "Output" panel in the render settings. There, select AVI JPG as the target.
  3. Render an animation. The resulting file will suffer from the problem.
Sergey, you should know what to do about that?
Bastien Montagne (mont29) raised the priority of this task from 30 to Normal.Oct 30 2014, 2:48 PM
@Bastien Montagne (mont29), @Campbell Barton (campbellbarton) is much better in ANI JPEG than me. If that was me, i'd just use FFmpeg backend, less code to maintain :)
Forgot to mention, @Campbell Barton (campbellbarton), i wouldn't really consider this a bug. More like a nice thing to support.. For more robust interchange i'd suggest using FFmpeg.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Mar 9 2015, 1:52 PM
Blender currently writes the AVI-1 spec which has a limit of 4gig. We could add support for AVI-1.02 but rather then spend time here probably its better just to use ffmpeg.
Closing as known limitation.
