Archlinux
GTX 460
Broken: 2.72b
Worked: 2.69
Rendering smoke in BI now requires the domain object's maximum draw type to be set to textured.
This is confusing, especially as the draw type is assumed (at least by me..) to be a viewport setting. Not to mention the "quick smoke" operator sets it to wire by default.
- Load factory settings
- Run quick smoke on the cube
- Play the animation a little so as to get some smoke (smoke is visible in the viewport)
- Enable viewport render (smoke is not visible in the render)
- Change the maximum draw type of the domain to textured (smoke will become visible in the render)
