Shrink/Fatten Bug | Modeling, Edit Mode, Polygons
Windows 7 Ult 64
GeForce GTX 580 1.5GB
Broken: All versions
Worked: Never
Edit Mode | Polygons
Weather you'd consider it a bug or a missing feature, Shrink/Fatten does not have desired functionality for Hard-Surface poly modeling. Provided video demonstrates the issue.
http://vimeo.com/111695386
Described in the video.
0rAngE (undo) raised the priority of this task from to 90.
0rAngE (undo) updated the task description. (Show Details)
0rAngE (undo) added a project: BF Blender.
0rAngE (undo) edited a custom field.
0rAngE (undo) added a subscriber: 0rAngE (undo).
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.EditedNov 13 2014, 9:27 AM
holding Alt will activate a method that takes thickness into account. (gives better results)
further, the feature is working as intended.
(Probably best you give text description too, I couldn't hear audio for the video you linked to, but this seems more like a request for a feature / change in behaviour then a bug)
Has anyone watched the video? I believe it demonstrates clearly what I'm trying to say.
I know about the ALT-key modifier for Shrink/Fatten (and Extrude).
I'm gonna make a guess here, I might be wrong as I'm not a programmer.
The issue is that the vectors for the transforms are always calculated by vertex normals.
But the Tools should be context sensitive. In turn, in Vertex mode it would behave as it currently does. But when in Face mode the vectors for the transforms should be calculated by face normals.
In the video I have provided examples of 2 other applications that have the desired functionality.
Campbell Barton (campbellbarton) changed the task status from Archived to Resolved.Nov 13 2014, 4:54 PM
This is really a feature request, so we typically close those immediately.
This has been suggested before, and guys here in the studio think its useful, so I've committed it.
Committed rB1ddfe6676de1b382d2c9b06cc9c68f50659d13de
Thanks on clearing it up, much appreciated!
If someone finds the time to implement this, would it be possible for someone to refer back to this 'Task Thread' and post?
Would love to be aware of this if implemented!
@0rAngE, not sure what you mean, its implemented now isn't it?, did you try a recent build?
Just tried a recent build from buildbot.
WOW!
...speachless.
Perfect.
Thanks!!!!!!!!!
