Grab-brush sculptmode on symmetryplane twice as fast
Min 8 Nvidia geforce 560
Broken: 2.72
Whil sculpting I found out, that the grabtool moves the vertices on the symmetryplane faster than the others.
in my opinion the the grab streinght was multiplied, because the mirrored stroke overlaps with the real stroke.
Try to grab vertices that are on the mirrorplane and compare the movement to vertices, who are not directly on the mirror.
Leonardo Kämpf (monatsend) raised the priority of this task from to 90.
Leonardo Kämpf (monatsend) updated the task description. (Show Details)
Leonardo Kämpf (monatsend) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Nov 21 2014, 8:27 AM
Most likely, those verts are moved (evaluated) twice... :/
It is the case for every brush.
It is the reason why there an option to avoïd this called "Feather" in Symmetry panel.
Ok,
If there is a option to avoid it, is this a real bug?
You may want this behavior to emphasize symmetry plane or point.
Maybe it can be considered as a bad default to have option off but not as a bug.
Ok. You have my vote for feathering OFF by default.
Best
Leo
I experimented with per vertex attenuation for brushes calculated from initial coordinates (other brushes suffer if the fix is applied on them) but the cost is greater and there is no consistently better behaviour. I'd say we keep things as they are now. Probably we can make feathering default for grab, but again, the result is not always nice. So I'll close for now.
Antonis Ryakiotakis (psy-fi) changed the task status from Unknown Status to Archived.Nov 27 2014, 4:04 PM
