No textures and fbx export problem undo problem
Win7. Radon HD 7800
Broken: (2.72 900e3ea, and current version)
  1. I have a model (deusXP white textures. The model has several materials, with several textures. In blender I only see 4 textures. The rest are just materials, with no texture visible.
  2. If I export to fbx, the console (with the 6 buttons and a small object below it) gets deformed. I tried exporting using the official and the beta. No difference.
  3. I am having a problem with undo. First I thought that it was because of installing addons. Now I have some projects like this one (Schepje where undo is broken. If I create a new scene, reset to factory settings and append the objects, everything works again. Problem is, that it gets broken during modeling as well. Undo history is blank than.
Also, I find it very frustrating that extrude region does not work automaticly in normal direction (and that extrude region normal, has no shortcut). What point is there to extrude region in another way than using the normal?
  1. Open the scene and see the result
  2. Export to fbx
  3. Open the scene and move one of the objects. try to undo.
daniel Cremers (danicrem) raised the priority of this task from to 90.
daniel Cremers (danicrem) updated the task description. (Show Details)
daniel Cremers (danicrem) edited a custom field.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Dec 15 2014, 10:29 PM
Please only report one bug per report. Else it's completely unmanageable for us.
So, answering your first point above, your model is using PSD pictures, which open white here for me in Blender and Gimp. Anyway, PSD files can only be opened reliably by Photoshop, please use common formats like PNG, JPEG, EXR if you need high dynamics, etc.
For your other issues, please make separated reports, with precise descriptions of the issue each time, and all files needed to investigate properly (like the exported FBX file, some screencaptures, etc.)
