Sun lamp shadows broken in GLSL view
Win 7 64bit
Mobility radeon 5650
Catalyst driver 12.10
Broken: blender-2.73-testbuild1-win64
Worked: Official 2.72b
Sun shadows in GLSL view do not look right. It appears the whole of the shadow map frustrum is filled with the shaded value. I'm attaching a comparison screenshots from the viewport. The bug happens with simple and variance shadow map style.
I do have older drivers, but everything worked well so far. If other cards work properly I could test with a newer driver version.
Revisions and Commits
Matjaž Lamut (lamoot) raised the priority of this task from to 90.
Matjaž Lamut (lamoot) updated the task description. (Show Details)
Matjaž Lamut (lamoot) edited a custom field.
Antonis Ryakiotakis (psy-fi) lowered the priority of this task from 90 to 30.Dec 16 2014, 1:44 PM
Test file or it didn't happen.
Just a note here, we had an issue there but was fixed 1-2 weeks ago. If this is happening on latest builds from builder.blender.org we really need a test file to reproduce.
I'm attaching a test file and a screenshot of how it looks like on my computer. It happens with a very simple setup already, default cube, plane and a sun lamp with shadows enabled.
I tested the file in the following blender versions with the same result.
blender-2.72-7234153-win64
Cannot confirm here... Smelling a driver issue, or something Windows related
Julian Eisel (Severin) raised the priority of this task from 30 to Normal.Dec 16 2014, 7:35 PM
Cannot confirm here either I'm afraid. Can you try with factory settings? Also, can you attach a system_info.txt file generated from blender (see http://blender.org/manual/vitals/help.html#diagnostics-options)?
Factory settings give the same result. I'm attaching the system_info file.
I'll see if I can test this on another OS tomorrow. Or if possible get the latest drivers installed (tricky due to manufacturer limiting which drivers can be installed).
Alright, I can confirm on the MacOS trashcan I'll see if I can fix this
Ok, I tested blender-2.72-7234153-linux-glibc211-x86_64 on Linux Mint 17 with default open source drivers and everything displays fine. It appears the issue is indeed with windows/driver.
It was a real issue after all, it's just that NVIDIA is often much more forgiving in OpenGL use. Thanks for the report!
I tested with the latest build from buildbot and the issue is gone here as well. Thank you for the fix.
