WIN7 SP1 2xAsus Rog
Broken: 2.72b
1- Open provided BALLON_SAMPLE.blend file
2- Select the curve object named "CURVE". The curve is shrink wrapped around the "BALLOON" object
3- Go to the curve's Object Data
4- Check and uncheck the "Fill Deformed" option to see that nothing changes. The procedural geometry around the circle remains affected by the shrink wrap modifier on the modifier stack of the circle no matter what. As I gather from the docs, the procedural geometry generated should come after any deformer if the fill deformed option is unchecked...
