Blender plays through a video better when the window is minimized
Widows 8.0 Intel HD 4600
Broken: 2.72b
This may be a windows or windows 8x problem
In the video sequencer the video plays at the correct frame frame rate however when the window is opened the frame rate drops to about 2 fps
My .blend for testing
Aaron Carlisle (Blendify) claimed this task.
Aaron Carlisle (Blendify) removed Aaron Carlisle (Blendify) as the assignee of this task.
Aaron Carlisle (Blendify) raised the priority of this task from to 90.
Aaron Carlisle (Blendify) updated the task description. (Show Details)
Aaron Carlisle (Blendify) edited a custom field.
Think this is normal and can be expected. If the window is open, the whole UI has to be drawn and the usual handling is done. I'd consider this as the root of the issue... @Campbell Barton (campbellbarton), @Bastien Montagne (mont29), do you agree here?
Assuming the window means the sequencer preview window?
In this case, then yes, this is to be expected - if the video editor is having to calculate effects, it will slow down playback until its cached.
Note that we're aware this sequencer could be optimized, but it doesn't really have an active maintainer,
Even so - this may be a TODO for gooseberry since its one of the requests from the team.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Dec 29 2014, 2:25 AM
Campbell Barton (campbellbarton) changed the task status from Archived to Unknown Status.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 30.
@Campbell Barton (campbellbarton) Yes the widow is the sequencer window. But it is never cached it will play through multiple times without caching. Also it will play at normal frame rate for about 2 seconds before returning to its 3 fps
Julian Eisel (Severin) changed the task status from Unknown Status to Archived.Dec 30 2014, 8:59 PM
Okay as @Campbell Barton (campbellbarton) said, this is to be expected.
it does not cache even if i plays through but if a play it at 1/4 the resolution it is cached and plays smooth.
I think it is a bug with the caching system.
Which resolution does the video have?
yeah, but I'm afraid 1080p is too much for our poor sequencer :/ That would mean it is cached, but our Blender is not able to render the frames fast enough to display at full frame rate.
If you want us to double check or if you don't believe me in this you can upload the video somewhere and I'll test it ;)
there is a .blend file in the description. and i like our poor sequencer ;)
