Panning in Sculpt Mode with tablet messes up 3d view.
Closed, ArchivedPublicTO DO
Mac OS Yosemite - NVIDIA GeForce GT 650M 1024 MB
Broken: 2.73
Worked: I can't remember, it's been so long. Sorry about the late report.
When I’m in Sculpt Mode and I’ve begun sculpting with my tablet, whenever I try to use the pan function, the object flies away from my view, until I press “fn” + “option” + "left arrow” to bring it back into focus.
Open any scene. Switch to Sculpt Mode. Plug in tablet. Sculpt one or more strokes. Press "Shift" + "Option" then Click mouse and drag. The 3d view should move far away from the object, putting it out of sight.
Here's an example -
https://www.youtube.com/watch?v=T7vOZB0u3qI&feature=youtu.be
Brandon Farley (farcgs) raised the priority of this task from to 90.
Brandon Farley (farcgs) updated the task description. (Show Details)
Brandon Farley (farcgs) edited a custom field.
Julian Eisel (Severin) lowered the priority of this task from 90 to 30.Jan 3 2015, 5:52 PM
As far as I can tell, the problem is tablet in absolute mode in combination with Continuous Grab. Optimally, Continuous Grab would be disabled for transformations if you're using a tablet.
I wanted to investigate this a bit further, too see what I can do code-wise, but after changing the tablet mode once, the problem didn't appear anymore (even after setting it back to absolute again). So chances are this is a driver issue (well even if so, I wouldn't deny that Blender's tablet support could be improved, but that's a different story and shouldn't go in here).
So could you just test if changing the tablet mode to relative and back again helps? If not, we'd need to investigate this a bit further.
I changed the mapping mode from "pen" to "mouse" and back and the problem still occurred.
mhh, okay, am I right that it works fine if you disable Continuous Grab (User Preferences->Input)?
Oh yes, that seems to fix it. Thank you.
Well, but that's no nice solution IMO. I'll see what I can do
Julian Eisel (Severin) raised the priority of this task from 30 to Normal.Jan 6 2015, 11:13 PM
Julian Eisel (Severin) changed the task status from Unknown Status to Archived.Jan 11 2015, 6:52 PM
Actually, I'd prefer this to be handled as a Todo -> Moved to Todo list: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Tablet_Support
