[Apologies if double-filed, this is my first bug report and I am not sure I found all the search settings in the bug tracking system to surface prior reports]
OS X Yosemite early access/beta 10.10.2 (14C68m)
*PLEASE NOTE* even though this deprecated API may be restored in another early access beta, it is still a good idea to remove references to deprecated code if possible.
Broken: All releases until 2.73rc1 (last one I tested)
Worked: do not touch the trackpad, just use a mouse (!), or use the workaround described in this reddit page (applied to Chrome, but same idea works for Blender): http://www.reddit.com/r/apple/comments/2n2b9c/os_x_10102_crashes_google_chrome/
In the case of blender, the terminal command is: env DYLD_INSERT_LIBRARIES=~/Desktop/patch.dylib "/Applications/blender.app/Contents/MacOS/blender"
Blender crashes instantly when touching/using Trackpad on any Mac running 10.10.2 with a Trackpad attached (desktop or laptop) due to parameter that was deprecated now being removed.
isResting was Available in OS X v10.6 through OS X v10.9, deprecated and removed in 10.10.2
Relevant crash report section:
- 8< ---------
Process: blender [13891]
Path: /Users/USER/Downloads/*/blender.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: 2.73rc1 (2.73rc1, 2014-Dec-24, Blender Foundation)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: blender [13891]
User ID: 501
Date/Time: 2015-01-04 09:32:09.255 -0800
OS Version: Mac OS X 10.10.2 (14C68m)
Report Version: 11
Time Since Wake: 880 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
- Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[NSTouch _initWithPreviousTouch:newPhase:position:isResting:]: unrecognized selector sent to instance 0x6180000a0180'
terminating with uncaught exception of type NSException
abort() called
- 8< ---------
