Basemesh edit to sculpt mode missing edges on wireframe but all verts mainfold normal
Windows 8, dual Nvidia 860M
Broken: 2.73b, 2.73
Edges missing in sculpt mode but are part of mainfold normals in edit mode
After re-topology of a base mesh, create a multi-resolution modifier, subdivide and check wire-frame in sculpt mode. On occasion there are missing edges.
Julian Eisel (Severin) lowered the priority of this task from 90 to 30.
I can't really see what you mean... Maybe a screenshot could help...
Don't see an issue here to be honest. The Multiresolution Modifier and the sculpt tool heavily affect the topology of the mesh, that's why you can't really recognize the original base mesh edges.
I think the missing edges you can see later in the video are a known issue of the multiresolution modifier algorithm. Not sure who wrote Multires... maybe @Nicholas Bishop (nicholasbishop)? Any input here?
Julian Eisel (Severin) raised the priority of this task from 30 to Normal.Jan 8 2015, 6:59 PM
Even a new base mesh yields the similar results when the multi-resolution modifier is applied. Missing edges. If that is a known issue then I guess that is all I was looking to know.
Okay, I think I was wrong about the algorithm issue, now I think the algorithm is just smart enough to ignore the edge. The reason for that is that the vertices at this place are building a flat plane, making this edge unnecessary. You can easily change that by transforming some of the vertices just a tiny little bit. Like here:
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Jan 13 2015, 3:29 PM
Sergey Sharybin (sergey) claimed this task.
it is not a bug, it's just optimization that if angle between two faces is small enough the edge is not drawn. You can disable it by going to Object buttons and enabling "Draw All Edged".
Thanks for the report, but i don't really see bug in here, everything works as intended.
