64bit Manjaro Linux, kernel 3.14.27
GeForce GTX 650 Ti, driver version 343.36
Broken: (example: 2.73 c24b694, see splash screen)
I lost about a day's worth of work after inadvertently introducing an object which would, with very specific circumstances, cause blender to crash if you opened the file or used the Undo function. After narrowing down the issue, it appears to occur with a specific object that uses the Mirror, Armature, Solidify, and Subdivision modifiers (in that order), and the crash condition is created when weights have been transferred to the affected object.
Just open this file:
Note 1: Splicing the problem object off into a separate file was tricky, since blender would sometimes crash when simply pasting a copy of the object!
Note 2: I also tested with the windows version of Blender, by running it under WINE. The crash still occurs there.
