Error on stretched Pole Target IK
Windows 7 64, GTX 980
Broken: bbf09d9 (2.73a) + 691cb61
Bone Constraint:
IK Stretch doesnt work combined with a Pole Target - Stretch scales to zero.
I dont know if this is a bug, but havent found something on the wiki about this behaviour.
Steps: (IK Setup)
  • Create an Armature
    • Create 3 Bones
      • Use 1 for IK-Solver Constraint
      • Use 2 as IK-Target
      • Use 3 as Pole Target
  • Select IK-Solver Bone
    • Go to Properties > Bone > Inverse Kinematics
    • Fill Stretch bar to 1.000
Problem:
The IK-Solver Bone disappears, i guess because of zero scaling and mainly because of the Pole target.
Using the Stretch Bone as part of a at least 2 part IK chain works fine.
But for some reason it dont work with a single bone setup.
Karja Krähwald (karja) raised the priority of this task from to 90.
Karja Krähwald (karja) updated the task description. (Show Details)
Karja Krähwald (karja) edited a custom field.
It seems IK stretch loses its target completely if a Pole target is assigned.
Check this by reducing the constraint influence.
I can reproduce this bug, if IK chain is only 1 bone.
Works fine with 2+ bones chain.
Works fine with 1 bone chain, but without pole.
--> KO for 1 bone chain with pole.
@Brecht Van Lommel (brecht), git blame says you did quite some work on this. Any chance you can look into this? *cateyes*
Julian Eisel (Severin) lowered the priority of this task from 90 to Normal.
Fixed now, thanks for the report.
