STL import/export scale is 1000x
Linux Ubuntu 14.04 32bit
NVidia GeForce G102M
Broken: 2.73a
the scale/sizes of import/export for STL mesh files are multiplied/divided by 1000
Export:
  1. open Blender, in right panel set Properties, Scene, Units, Metrics. The default cube is 2x2x2 m, see Dimensions in N right palette, or 3D View: Measure Panel in add-ons
  2. File, Export, Stl, Export STL
  3. Open FreeCAD, menù View, Environment, Part
  4. menù Modify, Preferences, General icon, Unit tab, set Standard (mm/kg/s/degree)
  5. Preferences, View icon, 3D view, 3D Navigation, set Blender style (mouse rotate, translate and zoom)
  6. menù File, New, menù File, Import, STL file
  7. use Measure tool to measure the object, it is about 2 mm
Using CURA a SW for 3D printers http://software.ultimaker.com/
I got the same result:
  1. menù File, Load model file, the cube is 2x2x2 mm (the floor checkerboard is fixed to 10x10 mm)
Import:
  1. Open FreeCAD, menù View, Environment, Part
  2. menù Modify, Preferences, General icon, Unit tab, set Standard (mm/kg/s/degree)
  3. Preferences, View icon, 3D view, 3D Navigation, set Blender style (mouse rotate, translate and zoom)
  4. menù File, New
  5. menù Part, Primitives, Prism
  6. select the object (double click), in left panel Properties, Box, set 100x100x100 mm
  7. use Measure tool to measure the object, it is about 100 mm
  8. menù File, Export, select Mesh Format, name as .stl file
  9. In Blender, menù File, Import, Stl, Import STL
  10. measure the object with 3D View: Measure Panel add-ons it is 100 m sized
Opening the STL file in CURA, it is 100x100x100 mm
So Blender export STL reduce the size of objects 1000 times, and import STL increase the size 1000 times
Valerio (efa) raised the priority of this task from to 90.
Valerio (efa) updated the task description. (Show Details)
Valerio (efa) added a project: BF Blender.
Valerio (efa) edited a custom field.
Valerio (efa) added a subscriber: Valerio (efa).
cube100mm_FreeCAD_exported:
cube2000mm_Blender_exported:
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Feb 23 2015, 12:05 PM
Thanks for the report, but there is no bug here. STL format does not store any unit information (nor define any default unit). This means there is no way to automatically know which scale to apply when importing, nor to define current unit during export. That’s why there is the 'Scale' option for import/export, to adjust to desired actual unit…
