1. I open blender
2. I add a texture to my material
3. I press the "colorband" button
4. Nothing happens (exept the button being pressed in)
5. If I try to change any parameters or anything, blender segfaults
If I press a button or change a parameter for the texture (F6 menu) before I press the colorband button I don't get this however.
Using blender 2.42 RC 1 on ububuntu dapper (32 bit), But I think I can recall having the same problems with a pretty recent CVS.build under windows too.
Oh, and I have some kind of integrated, low quality nvidia 3d card.
Logged In: YES
user_id=103
No crash here, latest cvs, OSX.
Vidar: You first should check if official releases (like 2.41) show same crashing. If so, then you most likely suffer an opengl issue. Check your drivers, driver settings, etc?
Logged In: YES
user_id=103
Move this to opengl issue tracker.
Vidar: in the RC2 test build this should be solved!
Logged In: YES
user_id=4929
The bug is not present in 2.41, nor is it fixed in the rc2.
I tried booting windows, but there everyting went fine.
A friend of mine (running Dapper too) does not get the crash however, so I guess the problem is on my side. Thanks for taking your time, and rock on!
Logged In: YES
user_id=103
Well. don't give up that easy! Did you check the Linux faq?
http://www.blender.org/cms/Linux.301.0.html
search for "NoFlip"
Checking on driver upgrades also could help
