VSE scene into scene offsync problem when changing duration
Closed, DuplicatePublic
Done with gooseberry branch on linux (not able to test with 2.74 since there is no "Use sequence" scene support in it)
to reproduce follow those steps :
1-in default scene, go to VSE and enqble AV-sync
2-import a video file with sound. adjust it to start at frame 1 of the timeline.
3-adjust start and end point of the timeline to fit duration of this strip
4-create a new scene (lets call it -edit scene-), go to VSE and add default scene into it at first frame (play the edit, everything should be fine and sync)
5-go back into default scene and change start point to frame 125 for exemple
6-go back to edit scene and playback your timeline.
2 unwanted things happens :
1 - strip audio is off sync, even when pressing refresh sequencer.
2 - in the edit scene, the default scene strip has changed in and out points. should display 25 black frames, then play normally starting from frame 25. Default strip scene in edit scene should keep sync as it were. frame 125 in default scene should still be frame 125 displayed at frame 125 in edit scene.
Workaround : go to the properties of the default scene strip in the edit scene. Set to 0 (which it is by default) the trim duration (hard and soft) for in and out points : strip adjusts its duration as it should (at the end of the strip). Then move the strip to make it start at frame 125 : that's how it should be. And sound is in sync again !
So apparently its not updating well when you switch scenes duration when the are added into one other as sequences...
mathieu auvray (matray) raised the priority of this task from to 90.
mathieu auvray (matray) updated the task description. (Show Details)
mathieu auvray (matray) edited a custom field.
This may be a dumb question but have you tried reloading strips?
Reload Strips - ALT + R
Reload Strips and Adjust Length - Shift + ALT+ R
Also can you post a .blend
Aaron Carlisle (Blendify) lowered the priority of this task from 90 to 30.Apr 7 2015, 10:49 PM
@mathieu auvray (matray) yep, to me Reload Strips and Adjust Length - Shift + ALT+ R works OK?
Or there is something I’m missing here…
Well it is still not behaving as expected when reloading and adjusting the length. A strip should never change position (move in time) whatever happens. If you have set in the EDIT SCENE the strip DEFAULT SCENE to have its frame 100 to be displayed at frame 125, changing in and out frame in the DEFAULT SCENE should'nt modify this or your edit changes and this scene into scene feature becomes useless...
Maybe we can close this, Im working on that specific issue with Anthonis (psy-fi) here in Amsterdam at the Institute...
Aaron Carlisle (Blendify) changed the task status from Unknown Status to Unknown Status.Apr 9 2015, 8:45 PM
Aaron Carlisle (Blendify) claimed this task.
that would probably be best i dont know why this was made if you have two developers right by you
Well because they are specialized on other things and have other urgent things to do ;)
