Linux Sabayon 64bit - Intel Quad Core Q9950 (6giga Ram) + AMD HD5870
2.70 and above up to 2.74 as far as I can tell, and may be some earlier versions as well.
Running a previously exported keyingset.py file in the text editor yields an error in a specific case. It happens when you have some keys belonging to the Shader Node editor (and probably the texture and compositing nodes as well).
Error: File "/keyingset2.py", line 13
id_0 = bpy.data.shader node trees["Shader Nodetree"]
SyntaxError: invalid syntaxExact steps for others to reproduce the error
(A blendfile with the script already loaded is available as a link at the end of the message)
Start a new project (Blender Internal or Cycles) with the default cube for instance, go to the material tab and enable "use node" for the current material.
Then in the node editor go with the mouse on whatever default value of any nodes, the color for instance or roughness and with the RMB menu do "Add to Keying set"
Go in the Scene Tab an the do "Export to File", then remove existing new keying set and open the text editor, load your "keyingset.py" file and run it, you should have an error because of this line:
Here is a full buggy keyingset.py file:
# Keying Set: ButtonKeyingSet import bpy scene = bpy.context.scene # Keying Set Level declarations ks = scene.keying_sets.new(idname="ButtonKeyingSet", name="Button Keying Set") ks.bl_description = "3 materials" ks.use_insertkey_needed = False ks.use_insertkey_visual = False ks.use_insertkey_xyz_to_rgb = True # ID's that are commonly used id_2 = bpy.data.shader node trees["Shader Nodetree"] id_1 = bpy.data.shader node trees["Shader Nodetree"] id_0 = bpy.data.shader node trees["Shader Nodetree"] # Path Definitions ksp = ks.paths.add(id_0, 'nodes["Diffuse BSDF"].inputs[0].default_value', index=-1) ksp = ks.paths.add(id_1, 'nodes["Diffuse BSDF"].inputs[0].default_value', index=-1) ksp = ks.paths.add(id_2, 'nodes["Diffuse BSDF"].inputs[0].default_value', index=-1)
I would like to ask for your attention to the fact that this keying set has been made with 3 keys from 3 different materials. As you may understand probably now there is a second more interesting dimension to the problem. Even if there were no unwanted spaces in the ID's, how blender could know which path belongs to which material ? The 3 ID's refer to the same unspecific "Shader Nodtree" node and this doesn't allow to differentiate the keys from the 3 different materials.
I have not done the test but a similar problem might occur with the Texture Nodes as well.
