Windows 7 x64, OS X 10.9, OS X 10.10.3, GPU: GTX 580 1,5GB + GTS 450 1GB - OS independent
Broken: 2.74-000dfc0 official release, 2.74-9e9a3cb, 2.73a-bbf09d9
Worked: 2.69 r60995
CUDA ERROR: Out of memory in cuLaunchKernel when rendering on GPU GTX 580 1,5GB and using Branched Path Tracing
Open Blender, load factory settings, enable CUDA GPU in Blender settings.
Switch to Cycles render engine, enable Compute Device: GPU.
Switch to Branched Path Tracing, enable square samples, set AA Render samples to 8, Diffuse to 3, Glossy to 3.
Select Lamp and set Samples to 8
Hit Render
- created in 2.69 - rendering ok
