64bit Manjaro Linux, kernel 3.19
GeForce GTX 650 Ti Boost, driver 346.59
Broken: 2.75 dev, hash 4288ab1
I was trying out the new Light Portals feature with a simple scene, and I found that, while it produced differing images with the default Path Tracing integrator, it had no efffect with the Branched Path Tracing integrator, and the two renders with it enabled and disabled were visually identical, but took about 3x longer to render. On the other hand, when Sample All Direct Lights and Sample All Indirect Lights are turned off, it begins to work, but portals instead seem to increase the amount of noise.
So, I'm guessing that either Branched PT is already better at what light portals do, or it simply isn't effective with Branched PT?
This is the .blend file I used for testing:
