Texture baking with shadow sampling leads to nondeterministic results (blender internal engine)
Archlinux, Sandy Bridge I5.
Broken: 2.74
Baking the same texture twice leads to different results.
  1. Open .
  2. Press "Bake" in render Panel.
  3. Look at generated texture.
  4. Press "Bake" again.
  5. Notice how texture changed.
Fabian Emmes (der_fab) raised the priority of this task from to 90.
Fabian Emmes (der_fab) updated the task description. (Show Details)
Fabian Emmes (der_fab) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.May 6 2015, 12:27 PM
Can confirm the issue, but not sure it is expected to be deterministic? Sergey, maybe you know? To me, there is no real reason to make it so here, and it would probably be harder to do too, deterministic reproducible randomness in multi-threaded context is rather hairy afaik…
Also, note that this is not really related to baking imho, this is valid for any render. This is just highly noticeable here because of very low res.
No, the normal render produces deterministic results, for every test I did (including this example). So I think this is baking specific.
Ack, yes, you are right, regular renders seems to produce same result always (at least with same amount of threads - changing that changes result)… So guess there is something wrong in handling of randomness in baking.
