OS X 10.8.5 NVIDIA GeForce GTX 780M 4096 MB
Broken: 2.68 - 2.74 4e7ef3f
Worked: 2.63
On mouse release (after curve adjust), cursor jumps (or appears) back on place of initial click in RGB Curve node.
https://dl.dropboxusercontent.com/u/55113627/RGB_Curve_behavior_50%25.mov
- add RGB Curve node
- drag and move curve to adjust
- on mouse release curve is adjured, but mouse pointer jumps back to initial click
I don't have all versions of blender now so I can't say when exactly this behavior occurred, but possibly with cycles RGB node.
2.63 and older versions works OK (this version of cycles is without RGB Curve node), 2.68 is first one I have on computer that works with this issue.
I use tablet, but I don't have a pen on it :)
I tried to disconnect tablet … the same behavior.
If you need some more info I can post I'm one big ear. Thank you
