Windows 7 64-bit, NVIDiA Quadro 1000M
Broken: rBd5f1b9c2223333e03f2e4994171ad9df8c1c4f21 and later
Worked: 2.74 release, and up to rB74df307ca43df14b759fd9eb6a049a6c5d90dcda
Freestyle line rendering gives no output lines when the Save Buffers option enabled.
- Start Blender with the factory settings.
- Enable Freestyle as well as the Save Buffers option, both in the Render properties window.
- Press F12 to render a still image.
- Observe that the default cube will be rendered without Freestyle lines.
The documented combination of Freestyle and Save Buffers options initially resulted in a fatal crash, which was partly addressed in rB8c1b805f87209ae6282d77b213ed2527f2d7c207. Still the Save Buffers option does not work as expected with Freestyle.
Acknowledgement: tksg8086 on Twitter for initial problem report.
