ubuntu 14.04 64 bits Nvidia Titan Black
Broken: 2.74.5 hash 1a0fb7e
In compositing nodes, when blend type of mix node is changed with alt key pressed, options of selected nodes (that have nothing in common) can change.
In this file, change blend type of mix node while pressing alt Key from Mix to Add or Substract or Divide....
By this action variable size option of blur node is enabled.
Change it to Mix or Multiply or Screen ...
Variable size option is disabled.
Same kind of things can happen with mask type of a Mask Type node.
