Motion Blur Bug
OS: Windows 7 (64 bit)
GPU: Zotac GTX-650 Ti 2GB Edition
Version: Blender 2.74
Hi developers.
If your character has "edge split" on with smooth shading, when you want to render animation with any tipe of motion blur, the bluriness is becoming very jumpy and goes to random directions.
<This bug is repeatable>
I sent you an example
If you can see the main character's motion blur is very buggy, but the duck's motion blur works perfectly (They are on the same Render Layer, and I used vector blur)
Works ok only, when character hasn't "edge split" modifier.
How to get this Bug.
1.Create an object and add some bones(use weight painting for bone moving system)
2.Make your bones IK(Inverse Kinematics)
3.Turn Smooth Shading on
4.Then add to the object "Edge Split" modifier
5.Animate a simple animation
6.Use the Cycles Renderer
7.Go to->Render Layers/Passes and check "Vector" on
8.Then enable "motion blur" from Render Settings, or "vector blur" from Node Editor
9.Render Animation
10.In your video you can see, that your character's motion gets stretched rapidly all over the place.
Please fix this bug, or people have to add motion blur in other video editing softwares, which are not doing it right often, Btw this is the BEST program ever(Im not joking), Keep improving your awesome Masterpiece and sorry for my not perfect English. :)
Eric Asriyan (Eric_Asriyan) renamed this task from Motion Blur bug to Motion Blur bug (Blurines flips all over the screen in random directions and sizes).May 31 2015, 9:26 PM
Aaron Carlisle (Blendify) renamed this task from Motion Blur bug (Blurines flips all over the screen in random directions and sizes) to Motion Blur Bug.Jun 1 2015, 1:23 AM
Aaron Carlisle (Blendify) removed Aaron Carlisle (Blendify) as the assignee of this task.
Aaron Carlisle (Blendify) updated the task description. (Show Details)
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Jun 1 2015, 1:37 AM
If you use the edge-split modifier - this adds/removes geometry in a way thats incompatible with motion blur.
Your options are:
  • Disable the 'angle' option, and only split sharp edges.
  • Use auto smooth.
See warning:
https://www.blender.org/manual/render/cycles/settings/integrator.html#motion-blur
closing.
